Bartscher DeliCool II is a compact and stylish 120-liter refrigerated display cabinet designed for optimal product display in retail locations with limited space. This model is ideal for displaying snacks, salads, pastries or drinks, ensuring their freshness and visual appeal.
Key benefits:
Efficient cooling: The convection cooling system with two fans ensures even temperature distribution throughout the display cabinet (from +2 °C to +12 °C).
Excellent visibility: Glazing on all sides and double glazing not only save energy, but also allow customers to view the assortment from any angle.
LED lighting: The LED lighting integrated in the upper part is controlled separately, so the products remain visible even in darker rooms.
Flexible display: The set includes two height-adjustable chrome shelves, which make it easy to adapt the interior space to products of different heights.
Convenient maintenance: Automatic defrost function and digital temperature control (via rotary knob) facilitate daily operation of the equipment.
External dimensions: 710 x 575 x 685 mm
Power supply: 230V / 50Hz / 1N
Power: 0.16 kW
Capacity: 120 liters
Temperature range: from 2 °C to 12 °C
Cooling: Circulating air with 2 fans
Coolant: R290 / 0.060 kg
Energy efficiency class: B (EU No. 2019 / 2018)
Material: Chrome-plated grille, Plastic, glass
Height-adjustable intermediate shelves: Yes
Sliding door
Net weight: 56.6 kg.
Key benefits:
Power: 0.16 kW
Sliding door
